theplaceboeffe1
Feb 18, 2014Aspirant
NV+ Performance Problems
Hi, I just bought a second hand NV+ and put some older drives into the machine and I'm getting awful performance issues even though the drives are only a couple of years old. I'm getting on 3Mb/s w...
937carrera
Mar 25, 2014Aspirant
You might want to have a read through my fairly long thread at http://www.readynas.com/forum/viewtopic.php?f=21&t=75476&p=420248#p420248
There's some of my own performance tests and advice on using NasTester. In my case a firmware upgrade solved my problem and 14MB write / 34MB read speeds over CIFS were normal
