drhiii
Feb 26, 2013Aspirant
NV+ RAID Questions
I have poured over docs and posts but I just want to be double triple sure before embarking so am asking a redundant question I know... apologizies. I have an NV+. 2 drives running in bays 1 and 2...
Mar 10, 2013Guru - Experienced User
Just to clarify the space comment:
StephenB wrote: If you are running 4.1.x then you have a v1. You can't run 4.2.x or 5.x.x on that platform. 4.2.x is for x86 platforms, 5.3.x is for arm. You have a sparc.
If your disks are different sizes you will see more disk space on your platform.
xraid1 (which is what your platform uses) doesn't support unequal size disks. If you install 2x1 TB + 2x2 TB, the xraid 1 treats all disks as 1 TB (wasting space).
xraid2 doesn't behave that way, but your platform doesn't use it.
