odbro
Feb 20, 2016Aspirant
NV+ stuck at boot after rsync
Hello, I was trying to use rsync to backup my share, it started according to gui but I did´t see any files at destination. So I aborted, it said it would told me when it was done. I went to logs...
Feb 20, 2016Guru - Experienced User
This sounds like a full OS partition.
One option is to contact Netgear and ask for per-incident support (they will charge). If it is a full OS partition then it is easily fixed.
If you are comfortable with linux commands then it is possible to investigate/fix yourself. Though it is more challenging if the NAS won't boot.
