odbro
Feb 20, 2016Aspirant
NV+ stuck at boot after rsync
Hello, I was trying to use rsync to backup my share, it started according to gui but I did´t see any files at destination. So I aborted, it said it would told me when it was done. I went to logs...
odbro
Hello StephenB, what are we talking about in numbers ~ with Netgear support?
I am familiar with Linux but I can't connect to SSH the only port open is 2049 NFS.
Can you hint me to a guide on what files I have to modify/delete and how to connect?
Regards David
Regards David
- StephenBFeb 20, 2016Guru - Experienced User
odbro wrote:
Hello StephenB, what are we talking about in numbers ~ with Netgear support?Their pricing does depend on location, so you need to contact them - they should tell you up front. Last US pricing I heard was $75, but that might not be current.
Doing it yourself would require booting up in tech support mode, and then using telnet to get into the box.
From there you need to manually mount the OS partition, and look at the fullness and the inode use.
If the partition is full, then you need to find the offending logs (or dlna cache) and truncate them.
If you want specific commands, mdgm probably can do this while asleep. It's probably more efficient to PM him on this.
