network23
May 13, 2013Aspirant
NV+ stuck on "Booting..."
Switched from DSL to cable internet today. As a result, my NV+ lost its IP address. So I properly shut it down from the unit and restarted. It's now been a half-hour and it still says "Booting..."...
May 14, 2013Guru - Experienced User
Hopefully you have a backup, so you are ok no matter what.
Do you happen to know what firmware you are running? Also, does RAIDar see the NAS? (it might give you some more information).
