rnnvpuNC
Sep 09, 2014Aspirant
NV+ stuck on booting, including after trying os reinstall
I have an old NV+ from around 2005-2006 (I don't exactly recall). I have long since lost track of any warranty or support options that came with it that I may have registered for. I would be open ...
vandermerwe
Sep 09, 2014Master
Have you tried support, I think there may be a scheme where, if you buy a new readynas, they will help you to transfer the data. I'm not sure what the prerequisites are.
Contact them.
You symptoms may be related to a full OS partition, which is fixable.
You have a raid 0 volume that spans 2 disks?
What firmware?
Contact them.
What firmware?
- Jul 15, 2018Retired_Member
