rnnvpuNC
Sep 09, 2014Aspirant
NV+ stuck on booting, including after trying os reinstall
I have an old NV+ from around 2005-2006 (I don't exactly recall). I have long since lost track of any warranty or support options that came with it that I may have registered for. I would be open ...
Sep 09, 2014Guru - Experienced User
If you have a windows PC, try linux reader on disk 1 (http://www.diskinternals.com/linux-reader/)
Disk 2 won't work, the RAID in the NV+ v1 uses a parity disk (does not distribute parity blocks), and the parity disk only contains a formatted OS partition. The parity data (copy in your case) is there, but saved to the raw disk (not a partition).
Label the disks if you remove them, it makes identification of the main drive easier.
- Jul 15, 2018Retired_Member
