rnnvpuNC
Sep 09, 2014Aspirant
NV+ stuck on booting, including after trying os reinstall
I have an old NV+ from around 2005-2006 (I don't exactly recall). I have long since lost track of any warranty or support options that came with it that I may have registered for. I would be open ...
vandermerwe
Sep 09, 2014Master
The NAS should be able to recover the data no matter which disk fails, if you have an xraid array. It's just that out of the NAS only disk 1 is readable.
Of course if you have more than 2 disks then reading the entire array outside the NAS is more difficult.
If you don't want to worry then make sure you have robust backup arrangements.
- Jul 15, 2018Retired_Member
