rnnvpuNC
Sep 09, 2014Aspirant
NV+ stuck on booting, including after trying os reinstall
I have an old NV+ from around 2005-2006 (I don't exactly recall). I have long since lost track of any warranty or support options that came with it that I may have registered for. I would be open ...
Sep 09, 2014Guru - Experienced User
Yes. If disk 1 fails, the NAS will boot from just disk 2, and the shares will be accessible.
vandermerwe wrote: The NAS should be able to recover the data no matter which disk fails, if you have an xraid array. It's just that out of the NAS only disk 1 is readable.
The newer NAS handle the raid differently, the parity disk idea is only in the sparc v1 platforms (which have hardware accelerated RAID)
- Jul 15, 2018Retired_Member
