etis84
Jun 14, 2013Aspirant
NV+ V1: fsck running for over 7 days
Hello, I have exactly the same problem as you. Have you found a solution at the time? Thank you for your feedback MOD NOTE- Split off from original thread which was for NVX (viewtopic.php?...
etis84
Thank you for the quick answers!
I misread, mine is not a NVX but NV +.
So my latest version is 4.1.10.
2 TB disks are in the NAS for several months, but I wanted to do a volume check, and each time, fsck stick, still not finished after 5 days ...
I have a lot of files, including many hard links.
Do you think it relates to this problem: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=411838
If yes, how to update fsck.ext3 file ?
