etis84
Jun 14, 2013Aspirant
NV+ V1: fsck running for over 7 days
Hello, I have exactly the same problem as you. Have you found a solution at the time? Thank you for your feedback MOD NOTE- Split off from original thread which was for NVX (viewtopic.php?...
etis84
Jun 15, 2013Aspirant
Thank you for the link
e2fsprogs in 4.1.10 firmware is 1.40.11.
I downloaded the source of 1.42.7 and compiled on Readynas.
Result: fs check finished in 5 hours!
I suppose there is a bug in the 1.40.11 version with large volumes or many files or many hardlinks.
