yawood
Sep 30, 2014Aspirant
NV+ V1 will not change anything in Setup
I have just purchased a second hand NV+ (which was reportedly working OK). I have reset it to factory default and added four 500Gb drives. All appears to be OK according to RAIDar, as shown here (the ...
mdgm-ntgr
Sep 30, 2014NETGEAR Employee Retired
The NAS is running firmware that is almost 7 years old: http://www.readynas.com/forum/viewtopic.php?f=1&t=15059
It's quite likely that you have a browser compatibility issue. Are you able to try upgrading the firmware using a very old web browser version?
