grooovy
Mar 08, 2012Aspirant
NV+ V2 + DLNA + Toshiba 32SL800 = ZERO
Hi all! Just bought NV+ v2 updated firmware to the 5.3.3. Installed the latest ReadyDLNA add-on. I cannot see any images, play any mp3 files - they are not visible. I can see the sub folders whe...
grooovy
Mar 09, 2012Aspirant
Thanks for your help!
Sure. Here it is:
Thank you for looking into this!
Have a terrific weekend.
Alex
Sure. Here it is:
[2012/03/08 23:02:11] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/08 23:02:11] minidlna.c:911: warn: Creating new database...
[2012/03/08 23:02:11] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/08 23:02:11] minidlna.c:1000: warn: TiVo support is enabled.
[2012/03/08 23:02:11] scanner.c:727: warn: Scanning /c/media
[2012/03/08 23:02:11] upnpsoap.c:1739: warn: Returning UPnPError 402: Invalid Args
[2012/03/08 23:02:12] scanner.c:798: warn: Scanning /c/media finished (3 files)!
[2012/03/08 23:02:12] playlist.c:125: warn: Parsing playlists...
[2012/03/08 23:03:30] minidlna.c:153: warn: received signal 15, good-bye
[2012/03/08 23:05:07] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/08 23:05:07] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/08 23:05:07] minidlna.c:1000: warn: TiVo support is enabled.
[2012/03/08 23:09:37] minidlna.c:153: warn: received signal 15, good-bye
[2012/03/08 23:11:13] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/08 23:11:13] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/08 23:11:13] minidlna.c:1000: warn: TiVo support is enabled.
[2012/03/08 23:19:57] minidlna.c:153: warn: received signal 15, good-bye
[2012/03/08 23:21:39] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/08 23:21:39] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/08 23:21:39] minidlna.c:1000: warn: TiVo support is enabled.
[2012/03/08 23:30:20] playlist.c:125: warn: Parsing playlists...
[2012/03/08 23:31:00] minidlna.c:153: warn: received signal 15, good-bye
[2012/03/08 23:34:04] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/08 23:34:04] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/08 23:34:04] minidlna.c:1000: warn: TiVo support is enabled.
[2012/03/08 23:38:09] minidlna.c:153: warn: received signal 15, good-bye
[2012/03/09 22:57:10] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/09 22:57:10] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/09 22:57:10] minidlna.c:1000: warn: TiVo support is enabled.
Alex
