grooovy's avatar
grooovy
NV+ V2 + DLNA + Toshiba 32SL800 = ZERO
Hi all!
Just bought NV+ v2 updated firmware to the 5.3.3. Installed the latest ReadyDLNA add-on.
I cannot see any images, play any mp3 files - they are not visible. I can see the sub folders where I put the files, I can see the files via BROWSE menu in web admin
https://192.168.1.XXX/admin/index.html but there are two problems:
- I can see video files on my TV but unable to play any. The length is being displayed as 00:00:00 and when I click play i see error "Media is not supported" (the same file shared via Windows Media Player is playing as it should)
- I cannot see jpegs and mp3 at all. Tried refresh DLNA add-on and it did not help.
I did system reset with wiping all data, but it did not help.
Any ideas what is wrong?
Or I have just bought a piece og cr..p which states that it is DLNA CERTIFIED? Is this some kind og joke, NETGEAR?
Please, anyone help me with setting up DLNA.
THANK YOU!
Alex
  • I have the same issue but IM trying to play the files via my Sony BDP 490, it see's the files but it says they are corrupt aka wont play. But those files play via pc.
ProSupport for Business
