Bombenbodo
May 02, 2013Aspirant
[NVX] "fsck.ext4 for device /dev/c/c exited with signal 9"
Hi all, since upgrading my NVX from 2 x 3TB to 4 x 3TB I get daily warning messages about disk issues. Forcing a fsck run results into: ***** File system check forced at Thu May 2 13:46:12 ...
mdgm-ntgr
May 02, 2013NETGEAR Employee Retired
What version of RAIDiator are you running? Expansion on 32-bit systems such as the NVX is dangerous on 4.2.20-4.2.22. I assume you are sadly running one of those firmware releases?
Please contact NetGar support for assistance (See the Online Submission link in my sig), post your case number and do not run another filesystem check. You should only run such a check if support suggests that you do.
The best advice if you can access your data is to backup that data, verify manually if it is corrupted or not and do a factory default on 4.2.19 or 4.2.23 (the latter is due to be released soon) and restore your data from backup.
