lijh
Jan 24, 2015Aspirant
NVX stuck on booting
After firmware upgrade. Boot menu is accessible, but factory default/OS install/tech support will still stuck on "booting" message forever. Memory test still works. I had tried to unplug the power ...
Jan 24, 2015Guru - Experienced User
You should be able to migrate your disks to a pro6.
If you purchased in 2010, you could contact support. You could also try skipping the boot volume check, and see what happens.
If you a scratch disk (not part of the array), you could power down, remove all disks, and install just the scratch disk and see what happens.
