CptKlutz
Oct 20, 2014Aspirant
NVX X-RAID2: no volume expansion after disk ugrades?
Hi! I'm not getting any more space on my NVX after swapping in 2TB disks in slot 3+4. Originally it was installed with 4x1TB and last year I then upgraded 2 failing drives with 2TB's coming to a 2x...
mdgm-ntgr
Oct 26, 2014NETGEAR Employee Retired
Do you have an up to date backup?
You may wish to consider backing up your data and doing a factory reset (wipes all data, settings, everything), then restore your data from backup.
I could try expanding your volume manually if you prefer.
