bedlam1
Mar 26, 2019Prodigy
OS 6.10 Release
Can anyone advise on how the new features added in OS 6.10 (Highlit in RED below) can be viewed/accessed ?
New Features and Enhancements:
ReadyTIER support for data tiering, including
Al...
Sandshark
Mar 27, 2019Sensei
Marc_V wrote:
You will be bale to see the total number of consumed space and files on all shares by going into the share properties/settings. Calculation is independent of Quota, so Quota will not be required to be enabled to see this numbers.
Is this perhaps only visible when quotas are not enabled? I'm not finding this.
Marc_V
Mar 27, 2019NETGEAR Employee Retired
The feature should be within the Share's setting under the Auto-defrag option and above the size/quota setting.There should also be a text link that says "Calculate"
This should be visible even if Quota is not enabled, please let us know if there are any issues.
Regards
- OOM-9Mar 27, 2019NETGEAR Expert
The Consumed space calculation has been removed from the UI at this time. We found a critical memory related issue with this feature just before we were releasing. We are working on a fix for this memory issue to bring the feature back in the up coming release.
- GG-71Mar 29, 2019Aspirant
After I updated from 6.9.5 to 6.10.0
the Admin Page show me no more antivirus
and I can not install any app.
Bug or feature?
I can not change permissions on shares. After I changed something and press [Apply] I get "Folder operation failed."
- Equinox1Apr 28, 2019Guide
Please hurry on the space calculation feature....that would be really useful. That said, I completely understand the criticality of memory and how hard they are to fix.
it would have been great to mention this removal on the release notes, though.
- ronaldvr2132Jun 15, 2019Apprentice
How can I edit the settings after I enabled the new audit in the logging section? I have activated it and saw you can select the details of which level and for which share it is enabled, but after applying the apply button I can't find the way to come back to these settings to verify and alter them if I want to do so.
