bedlam1
Mar 26, 2019Prodigy
OS 6.10 Release
Can anyone advise on how the new features added in OS 6.10 (Highlit in RED below) can be viewed/accessed ?
New Features and Enhancements:
ReadyTIER support for data tiering, including
Al...
Marc_V
Mar 27, 2019NETGEAR Employee Retired
Hi bedlam1
Audit logging, Established connections and Improved logging can all be found by going to System>Logs
Improved logging gives customers more options on what they can filter, such as the level of severity, the category issue type, and setting date range filters. Search is also allowed now.
Audit logging was a highly requested feature that has been included on 6.10. You can audit protocols based on actions, user, file/folders. date ranges, and host/ip. This can be found on System>Logs>Audit. You may have to enable Auditing through System>Settings
Established connections found under System>Logs>Connections lets you see all active connections on the ReadyNAS. It's helpful for determining current usage and activity.
You will be able to see the total number of consumed space and files on all shares by going into the share properties/settings. Calculation is independent of Quota, so Quota will not be required to be enabled to see this numbers.
Most likely Settings for Maintenance and Update options will be under System>Settings.
Hope this helps!
Regards
msq
Apr 24, 2019Apprentice
Hi,
After uptodae on one of my RND102 devices to 6.10.0 hotfix 2 I can't see any of those:
- option to enable audit on the system >> settings page. The only new thing for me here (apart from missing av, but saw that in release notes) is the "Maintenance and Updates" part with two checkboxes for updates notification and auto-apply hotfix, nothing more
- system >> logs >> audit. It is just not there
- system >> logs >> connections, again - it is just not there
Any chance those are not available on RND10x devices or for some reason were (temporary ..?) removed in hotfix 2 release?
Thank you for your help!
- StephenBApr 24, 2019Guru - Experienced User
msq wrote:
This can be found on System>Logs>Audit. You may have to enable Auditing through System>SettingsAny chance those are not available on RND10x devices or for some reason were (temporary ..?) removed in hotfix 2 release?
The auditing is only available on the x86 NAS - not the RN100, RN200, or RN210 platforms.
- discopangpangApr 26, 2019Aspirant
what!?
