bedlam1
Mar 26, 2019Prodigy
OS 6.10 Release
Can anyone advise on how the new features added in OS 6.10 (Highlit in RED below) can be viewed/accessed ?
New Features and Enhancements:
ReadyTIER support for data tiering, including
Al...
msq
Apr 24, 2019Apprentice
This can be found on System>Logs>Audit. You may have to enable Auditing through System>Settings
Established connections found under System>Logs>Connections lets you see all active connections on the ReadyNAS. It's helpful for determining current usage and activity.
Hi,
After uptodae on one of my RND102 devices to 6.10.0 hotfix 2 I can't see any of those:
- option to enable audit on the system >> settings page. The only new thing for me here (apart from missing av, but saw that in release notes) is the "Maintenance and Updates" part with two checkboxes for updates notification and auto-apply hotfix, nothing more
- system >> logs >> audit. It is just not there
- system >> logs >> connections, again - it is just not there
Any chance those are not available on RND10x devices or for some reason were (temporary ..?) removed in hotfix 2 release?
Thank you for your help!
Apr 24, 2019Guru - Experienced User
msq wrote:
This can be found on System>Logs>Audit. You may have to enable Auditing through System>SettingsAny chance those are not available on RND10x devices or for some reason were (temporary ..?) removed in hotfix 2 release?
The auditing is only available on the x86 NAS - not the RN100, RN200, or RN210 platforms.
- discopangpangApr 26, 2019Aspirant
what!?
