spiderman1
Oct 11, 2015Guide
OS 6.4 Experience on Legacy Hardware
Just for the record, here is my performance page. Seems that everything seems to be working ok.
I wonder if any of you in the community running legacy hardware with moded CPUs (i.e...
paalj
Nov 23, 2015Aspirant
Ok, I managed to reinstall the app and then uninstall it. Now htop is the only app installed. "find" is still building up and is eating up my memory and cpu...
br,
Paal
Nov 23, 2015Guru - Experienced User
Maybe try installing 6.4.1-RC1, and see if that helps. If it doesn't, you might need to try a factory reset.
