peralesa
May 06, 2014Follower
OS Partition Full ReadyNAS Pro 6 - help
I have a ReadyNAS Pro 6 and from all of the topics that I have been reading I have the symptoms of the OS Partition being full! CIFS service not running, not being able to select it, web interface wo...
Bigbearf
May 06, 2014Aspirant
Ask mdgm for help via PM. He will probably ask you to put your RNP6 in Tech Mode and he can access your box and hopefully fix the full tmp partition. Btw do you have SSH enabled?
Hope this helps.
Bigbearf
Hope this helps.
Bigbearf
