jhaye1's avatar
jhaye1
OS6 remote Rsync backup and advanced options
Running OS 6.1.6 on RN102. It seems that Remote-Rsync_over-SSH backup doesn't accept to have both "Compression" and "Remove deleted files on source" advanced options enabled at the same time.
I have setup a backup job to do so via Rsync over SSH, towards a remote ReadyNAS.
It all works well when:
- I don't specify any other specific option
- I do enable "Compression" advanced option; In such case I have verified that the amount of transferred data is indeed substancially lower - roughly 40% less -, proving that compression is active
- I do enable "Remove deleted files on source" advanced option; In such case I have verified as well that it's working as expected
But it doesn't work once I enable both advanced options at the same time. I can succesfully save my job configuration with these settings, but when I re-open the settings again then both options are disabled. Moreover, I have verified that none of these options are applied when I run the job
This behavior is equally true with 6.1.5. I have not checked with any other earlier firmware version.
Hints ? Bug? Many thanks for any help :roll:
Jean-Marc
PS: note that this works like a charm with Radiator 4.2.25 on a ReadyNAS Utra, with both options enabled
  • StephenB's avatar
    It might be good to contact Netgear support (via support.netgear.com), to make sure this is entered in their tracking system. I wouldn't presume that they will do that based on a post here.
    You might also pm skywalker, referencing this thread.
  • Case logged at Netgear support team over more than 2 months ago. The support engineer has seen the issue, and escalated this to level-3 support. Still no news until know, although it still doesn't work with latest 6.1.7 release. Keep you posted if I get any valid feedback.
  • Got the following update from Netgear support:
    "Confirmation that this bug will be fixed in the next major release i.e. 6.2. Target date remains unknow though."
    I'll request to get this included in 6.1.8 (currently in beta)
ProSupport for Business
