jhaye1
Feb 11, 2014Aspirant
OS6 remote Rsync backup and advanced options
Running OS 6.1.6 on RN102. It seems that Remote-Rsync_over-SSH backup doesn't accept to have both "Compression" and "Remove deleted files on source" advanced options enabled at the same time. I have ...
Feb 11, 2014Guru - Experienced User
It might be good to contact Netgear support (via support.netgear.com), to make sure this is entered in their tracking system. I wouldn't presume that they will do that based on a post here.
You might also pm skywalker, referencing this thread.
