schalliol
Jul 24, 2014Aspirant
OS6 Troubles w/ RSYNC Config?
I've used OS4 with RSYNC between two ReadyNASes, but there must be something off for me because I'm having trouble configuring OS6 on the server.  I am happy to specify a single IP with no credentials...
mdgm-ntgr
Jul 24, 2014NETGEAR Employee Retired
Did you share the Pictures folder on the data volume on the Remote NAS using Rsync?
Note the Remote NAS for the purposes of this is the NAS that you are not running the backup job on. The NAS on which you are running the backup job does not need the Rsync service enabled (unless it is used for backup jobs run from other NASes).
Can you try specifying the path as "Pictures" (no quotes)?
With Rsync disabled on every share except Pictures I get this:
As you can see it is shared as [Pictures] (note: no brackets in the path).
# cat /etc/rsyncd.conf
charset = utf-8
#[Backup]
#path = /data/Backup
#comment = Backup folder
#use chroot = true
#uid = root
#gid = root
#[Videos]
#path = /data/Videos
#comment = Video folder
#use chroot = true
#uid = root
#gid = root
[Pictures]
path = /data/Pictures
comment = Picture folder
use chroot = true
uid = root
gid = root
#[Music]
#path = /data/Music
#comment = Music folder
#use chroot = true
#uid = root
#gid = root
#[Documents]
#path = /data/Documents
#comment = Document folder
#use chroot = true
#uid = root
#gid = root
