Retired_Member
Sep 05, 2015OS6 upgrade question on legacy Pro 6
Hi All, I have been reading the forum and came across the upgrade thread (OS6 now works on x86 Legacy). I have a couple quick questions so here they are. Is it stable at this point without re...
- Sep 06, 2015
1- Backup all your data since the upgrade will factory reset everything and wipe the data
2- download "PREP4TOR6_0.1-x86.bin"
3- install it like an add-on, then DON'T REBOOT yet.
4- download R4toR6_latest.bin
5-install it like a normal firmware upgrade.
At the t reboot, it will install OS6 6.3.5, it will take some times (10-15mins) so no worries. You can check when your readynas is ready with raidator, as usual.
viperhansa
Sep 28, 2015Virtuoso
Hi guys,
maybe the wrong tread, i made a post log time ago related to upgrade the below and i cannot find that post again.. :smileyembarrassed:
I even think it was un-answered too.
| Hostname: | xxx-nas-Pro |
| Model: | ReadyNAS Pro Business Edition [X-RAID2] |
| Serie: | xxxxxxA001CF |
| Fast programvara: | RAIDiator 4.2.27 |
| Memory: | 4096 MB [4-5-5-18 DDR2] |
| IPv4-adress: 1: | Not connected |
| IPv4-adress: 2: | 192.168.2.199 |
| Volym C: | Online, X-RAID2, 6 diskar, 51% av 13 TB använt |
1. Can i upgrade this to OS6?
if so i do the following:
2. Install PREP4TOR6_0.1-x86.bin from frontview
3. install R4toR6_6.3.5.bin (Or should i install something else?)
4. Start over with putting all my backed up data .... sigh.... ;-)
Which is the last working version for me? Do anyone anticipate any problems?
The reason why i want to do a upgrade is that lately my RN starting to behave and dont let me install/remove "apps" or accessing them, giving me a "connection refused"
on for example sickbeard/sabnzbd but all other web based site on the nas works.
Something is wrong but with my level of knowledge on the os i cannot find what causing it.
Best regards
Hans, Sweden
Retired_Member
Sep 29, 2015I think the business is the same as the PRO6. I followed the solution from Rootax and everything worked well. I am running latest version of 6.3.5 (not the Beta 6.4) and it has been solid.
So to answer:
Can i upgrade this to OS6? YES
I had to do a reboot after the R4toR6 add-on. You might want to do it anyway even though not everyone has reported to need it. It would have saved me an hour and some stress.
My first attempt I installed the add-on and then the update to R6.3.5.bin but the update did not go. I did a reboot and then installed the R6.3.5.bin again and the update worked.
Process
1. Back up your files! (I used the USB port on the RN and the back-up commands)
Not sure why your apps are not working currently...
Good luck
