Retired_Member
Sep 05, 2015OS6 upgrade question on legacy Pro 6
Hi All, I have been reading the forum and came across the upgrade thread (OS6 now works on x86 Legacy). I have a couple quick questions so here they are. Is it stable at this point without re...
- Sep 06, 2015
1- Backup all your data since the upgrade will factory reset everything and wipe the data
2- download "PREP4TOR6_0.1-x86.bin"
3- install it like an add-on, then DON'T REBOOT yet.
4- download R4toR6_latest.bin
5-install it like a normal firmware upgrade.
At the t reboot, it will install OS6 6.3.5, it will take some times (10-15mins) so no worries. You can check when your readynas is ready with raidator, as usual.
Retired_Member
Sep 29, 2015I think the business is the same as the PRO6. I followed the solution from Rootax and everything worked well. I am running latest version of 6.3.5 (not the Beta 6.4) and it has been solid.
So to answer:
Can i upgrade this to OS6? YES
I had to do a reboot after the R4toR6 add-on. You might want to do it anyway even though not everyone has reported to need it. It would have saved me an hour and some stress.
My first attempt I installed the add-on and then the update to R6.3.5.bin but the update did not go. I did a reboot and then installed the R6.3.5.bin again and the update worked.
Process
1. Back up your files! (I used the USB port on the RN and the back-up commands)
2. Install PREP4TOR6_0.1-x86.bin from frontview
3. install R4toR6_6.3.5.bin (Or should i install something else?)
4. Start over with putting all my backed up data .... sigh.... ;-)
Not sure why your apps are not working currently...
Good luck
dsm1212
Oct 05, 2015Apprentice
So it seems that 6.3.5 will run on a pro 6. Will 6.2.4 ever suggest that as an upgrade? I expected to wait for it to tell me when it is good to upgrade but maybe that is never going to happen again?
steve
- StephenBOct 06, 2015Guru - Experienced User
steve
6.3.5 is released on the RN200 series but is "early access" beta on the other platforms. Since it is beta, it doesn't come up as an upgrade.
I suspect Netgear will upgrade both 6.2.x and 6.3.x to 6.4 (which is also in beta now). So my guess is that at some point you'll see a 6.4 upgrade prompt, and never get the 6.3.5 one.
- dsm1212Oct 06, 2015Apprentice
And of course immediately after I asked, I was offered 6.4.0 :-). Need to look at the release notes.
thanks
Hmm. I'm a little wary of the release note that says you cannot downgrade after upgrading to this. I'm running 6.2.4. If someone upgrades from 6.2.4 to 6.4.0 on a pro 6 please let us know how it goes. I might bite the bullet on the weekend.
steve
