Treccani
Feb 17, 2018Aspirant
Out of Space Messages
I have 669 GB available but if I try to copy inside a file of 1,29 GB the window says: “I can't copy.......because no sufficient space free". Why?
Thank you for as kind reply.
- Feb 20, 2018
If your backup is up to date I would
1. Update to 6.2.5
2. Update to 6.5.2 following this one-off procedure: ReadyNAS OS 6: RN100/RN2120 cannot update due to invalid checksum
3. Update normally to 6.9.2
4. Do a factory reset (wipes all data, settings, everything) and restore your data from backup.
Btw we have a ReadyNAS Community for Italian speakers if you prefer to use that.
Feb 17, 2018Guru - Experienced User
What firmware are you running?
Are quotas enabled?
