Treccani
Feb 17, 2018Aspirant
Out of Space Messages
I have 669 GB available but if I try to copy inside a file of 1,29 GB the window says: “I can't copy.......because no sufficient space free". Why?
Thank you for as kind reply.
- Feb 20, 2018
If your backup is up to date I would
1. Update to 6.2.5
2. Update to 6.5.2 following this one-off procedure: ReadyNAS OS 6: RN100/RN2120 cannot update due to invalid checksum
3. Update normally to 6.9.2
4. Do a factory reset (wipes all data, settings, everything) and restore your data from backup.
Btw we have a ReadyNAS Community for Italian speakers if you prefer to use that.
Feb 17, 2018Guru - Experienced User
What firmware are you running?
Are quotas enabled?
Treccani
Feb 18, 2018Aspirant
The firmware is 6.1.6.
"Quotas enabled" I don't understand what means.
Thank you.
- TreccaniFeb 18, 2018Aspirant
I found even this problem that also I don't understand (see screenshot in italian) and translation is:
"Alarms.
Update of the antivirus scanner definition file failed due to an error during the download. Check the internet connection."Internet works very well.
Thank you again.
- mdgm-ntgrFeb 18, 2018NETGEAR Employee Retired
6.1.6 is extremely old firmware. Is your backup up to date?
I know that the firmware is old but I'm afraid to update it because in the past, after an update, all went to block and got corrupted and Netgear recognizing the error has changed the entire disks completely free.
The backup is up to date.
What do you advise me to do?
Thank you very much for your support.
