Treccani
Feb 17, 2018Aspirant
Out of Space Messages
I have 669 GB available but if I try to copy inside a file of 1,29 GB the window says: “I can't copy.......because no sufficient space free". Why?
Thank you for as kind reply.
- Feb 20, 2018
If your backup is up to date I would
1. Update to 6.2.5
2. Update to 6.5.2 following this one-off procedure: ReadyNAS OS 6: RN100/RN2120 cannot update due to invalid checksum
3. Update normally to 6.9.2
4. Do a factory reset (wipes all data, settings, everything) and restore your data from backup.
Btw we have a ReadyNAS Community for Italian speakers if you prefer to use that.
Treccani
Feb 18, 2018Aspirant
I know that the firmware is old but I'm afraid to update it because in the past, after an update, all went to block and got corrupted and Netgear recognizing the error has changed the entire disks completely free.
The backup is up to date.
What do you advise me to do?
Thank you very much for your support.
mdgm-ntgr
Feb 20, 2018NETGEAR Employee Retired
1. Update to 6.2.5
