Kamcio
Apr 28, 2016Apprentice
Overview now shows USB HDD system VFAT partition
Dear Commnity, I have the same issue as Andrew86: https://community.netgear.com/t5/Using-your-ReadyNAS/Overview-now-shows-USB-HDD-system-VFAT-partition-after-6-4-0/td-p/992389 I want to back...
mdgm-ntgr
Apr 28, 2016NETGEAR Employee Retired
Do you still see this on ReadyNASOS 6.5.0 (RC1) ?
Kamcio
Hi,
I have downloaded the ARM Version and started the upload. Unfortunately after a few seconds the windows closes without any info. So I can't it check :-(
- KamcioApr 28, 2016Apprentice
I have found in logs:
"Volume: System volume root's usage is 100%. This condition should not occur in normal conditions. Contact technical support"
Perhaps is it the reason why I can't install the new firmware?
Btw. I have 3.90 TB free on my NAS
- StephenBApr 28, 2016Guru - Experienced User
Yes. The root partition is a 4 GB (not TB) partition that holds the NAS operating system (and which the NAS boots from). It's not the same as your data volume.
Thank You Stephen for the explanation.
I have found in Internet some suggestions how to lose this problem but which is the best one? :-/
