Corax
Jun 08, 2017Aspirant
Partitioning 2 volumes
Hello guys, I need help here, all the others topics are too old and don't fit with what I'm trying to achieve. I have a 2To and a 4To loaded in my ReadyNAS Duo, and I'd like to separate in half t...
Jun 08, 2017Guru - Experienced User
What firmware are you running? The Duo v1 (4.1.x firmware) won't handle disks larger than 2 TB.
- CoraxJun 08, 2017Aspirant
Hey,
I'm running on 6.7.4, and I can't tell you if it's a V1 or not- StephenBJun 08, 2017Guru - Experienced User
If you are running 6.7.4, then you don't have a Duo at all. You have one of these:
- RN102
- RN202
- RN212
- RN312
- RN422
Can you post a screenshot of your current volumes tab (from the admin web ui)?
- CoraxJun 09, 2017Aspirant
Okay, it's written RN102. But I was sure it was a duo :/
