lyndon68
Feb 06, 2013Aspirant
password problem on my NV+ V2
Hi, Not sure where to ask this as it's my first post here. So sorry if it's posted in the wrong place :-) I have read through all the frequently asked questions but still have been unable to re...
mdgm-ntgr
Feb 07, 2013NETGEAR Employee Retired
The default password for the NV+ v2 is password and the default password for the NV+ (v1) is netgear1. The admin username is admin for both.
The NV+ v2 has a charcoal chassis whereas the NV+ (v1) has a silver chassis. The two are quite different devices.
Sounds like there may be a problem with your /etc/passwd or /etc/shadow file or some other issue on the OS partition. It's possible a L3 tech may need remote access to investigate this issue.
Open a support case if you haven't already (if over 90 days since purchase, use the Online Submission link in my sig).
- Aug 10, 2022Retired_Member
