md96
Sep 14, 2014Aspirant
Permission problem with sparsebundle in user share
I've set up TM on my MBP (Mavricks) to back up to my user share on my ReadyNAS Duo v2 following these instructions: viewtopic.php?f=71&t=59974 It works fine, mostly. But, as others have observed,...
md96
Sep 16, 2014Aspirant
Ok. That makes sense.
Sorry to be such a n00b, but I'm not sure how to check that nor what the correct permissions should be. [I've only recently switched to Mac OS.]
I've installed the ARM add-in to allow SSH root access. [I needed to do that first, right?]
But, now when I use cyberduck to SSH in, it gives me errors, whether I'm using the admin account or the user account. {I've tried to look around the forum for advice, like here, viewtopic.php?f=11&t=45118, but it mostly seems to assume that I've already been able to login via SSH.}
Thanks for additional tips/links.
I'll type up a step-by-step for the forum, if/once I get it working.
