md96
Sep 14, 2014Aspirant
Permission problem with sparsebundle in user share
I've set up TM on my MBP (Mavricks) to back up to my user share on my ReadyNAS Duo v2 following these instructions: viewtopic.php?f=71&t=59974 It works fine, mostly. But, as others have observed,...
md96
Sep 17, 2014Aspirant
Thanks. I'll look into 5.3.10. Do you know if the update fixed the timeout/connection errors that makes it necessary to 'repair' the backup? (If so, I'd be happy to update and start a new TM backup. But if I'm going to have to re-start every month, then I should probably figure out how to fix this).
I followed these instructions to backup to a user share (not one that's manually created). viewtopic.php?f=71&t=59974
The instructions are written assuming Frontview, but I either modified and/or found instructions deeper in the thread about how to do it on an ARM NAS.
I'm running Mavricks.
The output from the cat cmd is:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>CFBundleInfoDictionaryVersion</key>
<string>6.0</string>
<key>band-size</key>
<integer>8388608</integer>
<key>bundle-backingstore-version</key>
<integer>1</integer>
<key>diskimage-bundle-type</key>
<string>com.apple.diskimage.sparsebundle</string>
<key>size</key>
<integer>3918161387520</integer>
</dict>
</plist>
*note* I modified a different file inside the sparsebundle following the instructions here: http://www.garth.org/archives/2011,08,2 ... rrors.html
{I put all this info in my original post -- not trying to be snarky, just don't want you to think I hadn't said as much. :D}
The second command (du) generates this:
173G /c/home/username/macbookpro.sparsebundle
173G total
Any other hints? If you tell me the update likely fixed my issue, I'll try it. And wait. And, if I get this problem again come back with a follow-up in a few weeks.
<dict>
<key>size</key>
</dict>
</plist>
173G total
