CBCC
Apr 04, 2014Aspirant
Permissions over Network
Hello, I am having trouble with my ReadyNAS Duo V2. I can do anything I want to from the WinXP computer that originally put the files on it, but not with other computers on my network. The ReadyN...
tony359
Apr 05, 2014Apprentice
Formatting won't help. A Factory reset will recreate your volumes and if the new firmware has changed the way the volumes are created/handled, you will end up with the new settings. Sometimes new features require a factory reset, data cannot be retained.
Having just 500GB in your Duo, it should not be a problem to factory reset. Update the unit and when it's done just do a factory reset. That will wipe your unit of course.
