Sushiboy
Aug 12, 2014Aspirant
Pinging from ReadyNAS Duo
Issue: Transmission no longer seen as seeding torrents to a private tracker.
I need to be able to ping the tracker from the NAS. How do I do that?
- SushiboyAspirant
StephenB wrote:
If the trackers or the peers you are connecting with use 5.x.x.x addresses, there is an IP address conflict - since remote hijacks the 5.x.x.x address space.Sushiboy wrote: I discovered by disabling ReadyNAS Remote that it was the culprit and apparently causing a conflict with Transmission. So that problem is isolated but not resolved.
If that is the cause, there is no workaround other than disabling remote.
That wouldn't be the problem. - mdgm-ntgrNETGEAR Employee RetiredWhat version of ReadyNAS Remote are you running?
- SushiboyAspirantver. 1.0.9.78
