btaroli
Dec 01, 2016Prodigy
Planning Ahead for Capacity Upgrade
Well, the ol' 4TB based volume in my 516 is down below 3TB free space. FWIW, this somehow got created as a RAID-5 under X-RAID2, but with 4TB disks it wasn't so bad. After some thought and looking at...
- Dec 01, 2016
The volume will only expand when redundant space can be added. So if you have one 12TB disk after the RAID-6 volume is rebuilt you will still have dual-redundancy.
After you've created the RAID-6 volume you can re-enable X-RAID.
In fact depending what disks are installed, with a RAID-5 volume with three or more disks you could disable X-RAID and designate it so that when the next empty slot is filled it is used to add parity (i.e. convert to RAID-6). This conversion does take a long time though.
mdgm-ntgr
Dec 01, 2016NETGEAR Employee Retired
btaroli
Dec 01, 2016Prodigy
I did notice the option for adding a parity disk along the way, in FlexRAID mode, but these drives are a bit too large to want to wait around for that to happen. I considered the possibility of migrating the disks over to the new NAS. I suppose if that worked (both are on 6.6) then I could add a second parity disk to the volume and then single swap in 8TB disks...? Might save time overall, instead of syncing data and setup around...
