btaroli
Dec 01, 2016Prodigy
Planning Ahead for Capacity Upgrade
Well, the ol' 4TB based volume in my 516 is down below 3TB free space. FWIW, this somehow got created as a RAID-5 under X-RAID2, but with 4TB disks it wasn't so bad. After some thought and looking at...
- Dec 01, 2016
The volume will only expand when redundant space can be added. So if you have one 12TB disk after the RAID-6 volume is rebuilt you will still have dual-redundancy.
After you've created the RAID-6 volume you can re-enable X-RAID.
In fact depending what disks are installed, with a RAID-5 volume with three or more disks you could disable X-RAID and designate it so that when the next empty slot is filled it is used to add parity (i.e. convert to RAID-6). This conversion does take a long time though.
btaroli
Dec 01, 2016Prodigy
So I've got the disks over in the other box now. And I've begun the process of adding a parity disk. Given the fullness of the volume, it suggests it will take 10 days! We shall see... but I have no reason to doubt it. heh
Dec 01, 2016Guru - Experienced User
The resync time doesn't depend on the volume fullness. But of course it does take a while - every sector on every disk in the data volume needs to be either read or written at least once.
For other posters - OS-6 RAID doesn't actually use the "parity disk" idea. Parity and data blocks are evenly distributed across all the disks. That spreads the I/O across all drives, which has performance benefits.
