btaroli
Dec 01, 2016Prodigy
Planning Ahead for Capacity Upgrade
Well, the ol' 4TB based volume in my 516 is down below 3TB free space. FWIW, this somehow got created as a RAID-5 under X-RAID2, but with 4TB disks it wasn't so bad. After some thought and looking at...
- Dec 01, 2016
The volume will only expand when redundant space can be added. So if you have one 12TB disk after the RAID-6 volume is rebuilt you will still have dual-redundancy.
After you've created the RAID-6 volume you can re-enable X-RAID.
In fact depending what disks are installed, with a RAID-5 volume with three or more disks you could disable X-RAID and designate it so that when the next empty slot is filled it is used to add parity (i.e. convert to RAID-6). This conversion does take a long time though.
btaroli
Dec 02, 2016Prodigy
But why play block level RAID games any more? Time for ZFS or Btrfs to properly take over. ;) I haven't been closely following the progress on making Btrfs "raid" protection more solid. But I know ZFS is already there. Between the two, I think I prefer Btrfs'es approach because it makes changing protection levels a bit more fluid; as opposed to ZFS which does creare more rigid relationships beteeen physical devices.
As an update, we're over a day into adding a second parity to this array and it's not quite 10%. Looking very much like it's going to take two weeks! Crazy.
Dec 02, 2016Guru - Experienced User
Not production ready yet. https://btrfs.wiki.kernel.org/index.php/RAID56
