btaroli
Dec 01, 2016Prodigy
Planning Ahead for Capacity Upgrade
Well, the ol' 4TB based volume in my 516 is down below 3TB free space. FWIW, this somehow got created as a RAID-5 under X-RAID2, but with 4TB disks it wasn't so bad. After some thought and looking at...
- Dec 01, 2016
The volume will only expand when redundant space can be added. So if you have one 12TB disk after the RAID-6 volume is rebuilt you will still have dual-redundancy.
After you've created the RAID-6 volume you can re-enable X-RAID.
In fact depending what disks are installed, with a RAID-5 volume with three or more disks you could disable X-RAID and designate it so that when the next empty slot is filled it is used to add parity (i.e. convert to RAID-6). This conversion does take a long time though.
btaroli
Dec 04, 2016Prodigy
ticket 27750873 submitted
btaroli
Dec 04, 2016Prodigy
Replaced by ticket 27750891, since I goofed and entered the wrong email in the first one. Fun.
- mdgm-ntgrDec 04, 2016NETGEAR Employee Retired
This appears to be a minor issue that in some rare cases may be run into when migrating disks from one chassis to another.
Edit: Your system looks fixed now.
- btaroliDec 04, 2016Prodigy
Yes, it seems so. :) A bit of a scare! Hadn't see this sort of thing, as I've never moved disks between boxes before. Appreciate your help!
- FramerVDec 04, 2016NETGEAR Employee Retired
Hi btaroli,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
