btaroli
Dec 01, 2016Prodigy
Planning Ahead for Capacity Upgrade
Well, the ol' 4TB based volume in my 516 is down below 3TB free space. FWIW, this somehow got created as a RAID-5 under X-RAID2, but with 4TB disks it wasn't so bad. After some thought and looking at...
- Dec 01, 2016
The volume will only expand when redundant space can be added. So if you have one 12TB disk after the RAID-6 volume is rebuilt you will still have dual-redundancy.
After you've created the RAID-6 volume you can re-enable X-RAID.
In fact depending what disks are installed, with a RAID-5 volume with three or more disks you could disable X-RAID and designate it so that when the next empty slot is filled it is used to add parity (i.e. convert to RAID-6). This conversion does take a long time though.
btaroli
Dec 11, 2016Prodigy
Nearly 70% today... and then a bad turn. Someone turns off the power strip with the NAS on it. I find it later and it boots up with volume mounted, but resync doesn't seem to be running despite showing 69.4% completed. I try for clean restart from web interface and it comes up with no data volume. Shows "offline" volume with all the drives in it, but not sure how to proceed.
Submitted SR 27783352 and waiting to hear back. Logs and diagnostic access included.
FramerV
Dec 12, 2016NETGEAR Employee Retired
Hi btaroli.
Given the event that occurred and as well as its result it was a good idea to get support already. I would have advised to do so if in case.
They should provide updates once the checking on the back-end is done.
