smccarthy945
Mar 31, 2015Aspirant
Planning for DR on XenServer
I have several ReadyNas Units - RN 104 and ReadyNas 314 units. I would like to know if I buy a couple backup units just to have in inventory and I have a unit die, can I just move the drives from one ...
Nhellie
Mar 31, 2015Virtuoso
That is okay I believe, when migrating the drives you need to make sure that the drives are on the same slot. If the chassis and the drives does not have the same FW upon migration, the chassis will force firmware update the drives so might as well insert a blank disk and initiate a factory default. Once the FW are the same, you can then migrate the drives.
http://kb.netgear.com/app/answers/detai ... -system%3F
