smccarthy945
Mar 31, 2015Aspirant
Planning for DR on XenServer
I have several ReadyNas Units - RN 104 and ReadyNas 314 units. I would like to know if I buy a couple backup units just to have in inventory and I have a unit die, can I just move the drives from one ...
Mar 31, 2015Guru - Experienced User
Probably better to keep the backup unit running, and keep the disk contents current with frontview backup.
smccarthy945 wrote: So can I simply throw some drives in the backup unit to update it and then shut it down and remove the drives? In the event I ever need it, I can move the drives from the failed unit to the backup unit and boot it up?
Then if the drives fail you have a backup.
