Dinky
Feb 09, 2011Follower
Playlists help
Hi, So far I'm really impressed with my Duo - it's all working well. Only one thing I can't get it to do! I cannot get it to pick up playlists I create. This is the process I go through: Export a...
rcrampton
Jul 09, 2011Aspirant
In case it saves anyone else the hour it took me to figure this out....
I exported my playlist from iTunes on my Mac and copied it onto my ReadyNAS, modified the paths to point to the right place, the playlist showed up on my WD TV Live but when I tried to play the list it said "no media".
I ended up editing the file in vi and saw that the carriage returns / line feeds showed as ^M and determined this was hosing things.
Used vim to fix according to this wiki:
http://vim.wikia.com/wiki/File_format
