Dinky
Feb 09, 2011Follower
Playlists help
Hi, So far I'm really impressed with my Duo - it's all working well. Only one thing I can't get it to do! I cannot get it to pick up playlists I create. This is the process I go through: Export a...
brianbug
Oct 18, 2011Aspirant
Hi,
I have a ReadyNAS Duo using DLNA/UPnP to stream music to my Pure Sirocco 550 Media Player.
I initially had problems streaming the music but after doing the RAIDiator 4.1.8 and the DLNA 1.0.21
updates this has solved these issues & I can now stream the music.
However, the Sirocco will not recognise the playlists (.m3u or .wpl) stored on the Duo created
by WMP from the music stored on the Duo - after selecting Playlist on the Sirocco
all I get is "no tracks found". The same Duo playlists will quite happily play on a PC(win7) using WMP
and the Sirocco will happily play playlists created from music stored on a PC(win7) by WMP.
After many emails with the technical people at Pure they tell me they belleve the reason is because the Duo
is not fully compliant with UPnP standard v1.0 ??
Any adice/help greatly appreciated.
thanks
Brian Buggins
thanks
Brian Buggins
