Dinky
Feb 09, 2011Follower
Playlists help
Hi, So far I'm really impressed with my Duo - it's all working well. Only one thing I can't get it to do! I cannot get it to pick up playlists I create. This is the process I go through: Export a...
brianbug
Oct 18, 2011Aspirant
Hi
I have just received this email(below) from Pure re. my Playlist problem - not sure it helps
-any comments welcome :-
Windows Media Player is not a UPNP client or server, please try Twonky as per my colleagues previous instruction.
The fact that the Sirocco can read an M3U from windows media player suggests that the problem isn't with this protocol, nor is it with UPNP as this is fully tested and compliant, the NAS must be running some other form of background process that is causing an incompatibility issue.
Regards
Brian Buggins
Regards
Brian Buggins
