Dinky
Feb 09, 2011Follower
Playlists help
Hi, So far I'm really impressed with my Duo - it's all working well. Only one thing I can't get it to do! I cannot get it to pick up playlists I create. This is the process I go through: Export a...
sphardy1
Oct 18, 2011Apprentice
There are multiple levels of fail in that response, but the bottom line is - as the saying goes - the nice thing about standards is that there are so many to choose from...
There are multiple UPnP AV servers that claim various levels of compliance with different so-called standards, that you never know what client will really work with what server until you try it. So assuming you have not made any error in you playlist file, there's little more you can do directly, and it's difficult for users like us to debug if the fault lies in the client or the server.
It doesn't seem Pure - who are best positioned to help - has much interest in making their units work with ReadyNAS devices.
You could try posting on the minidlna forum - perhaps you might get help: http://sourceforge.net/projects/minidlna/
(minidlna is the UPnP AV server application running on ReadyNAS devices - they just rename it)
