jeffvenuti
Oct 17, 2015Aspirant
Please Help: can't ssh, can't start services_case nos.: 25913382 / 25923232
My problems started this morning by getting this email message every 10 minutes:
System volume root usage is 81 %. This condition should not occur in normal conditions. Please contact technical...
DaneA
Oct 19, 2015NETGEAR Employee Retired
Hi jeffvenuti,
It appears that you have already contacted NETGEAR Support and opened a case regarding your concern. Kindly answer the questions below:
a. Do you have a backup of all the data stored in your NAS?
b. Have you tried to perform a factory reset on the NAS?
c. Can you still set the NAS to telnet mode?
If ever you have a backup of all your data, you may perform a factory reset on your NAS and this will let you configure the NAS from scratch. However, if a factory reset is not an option and since SSH access is not possible, hope that the NAS can still be set on telnet mode.
Just to set your expectation, if ever the NAS can still be set on telnet mode, you will need to agree with the NETGEAR remote access policy then your case would be escalated to a higher tier support to remotely access the NAS and fix it. Please be reminded, if ever the NAS is not within the support warranty, you will need to purchase a support contract for it before the case gets escalated to a higher tier support.
Welcome to the community! :smileyhappy:
DaneA
NETGEAR Community Team
- jeffvenutiOct 19, 2015Aspirant
Hi DaneA,
To answer your questions:
a. I do not have a backup of the data. But through the GUI I can see that the Shares are all there and data is accessible. If you can advise on how to backup this data I will do so. Can I do this through the GUI?
b. Since I don't want to lose any data I have not tried to perform a factory reset.
c. I don't know how to set the NAS to telnet mode. Never tried. I can access the GUI and under settings I can see all the services (SMB, HTTP, SSH etc.) but nothing seems to respond to being selected. Is this the same place telnet mode is selected?
I'm fine with agreeing to the NETGEAR remote access policy.
Is there a way to access the NAS directly somehow? I feel like if I can just get in and restore the old /var directory then everything will be fine. Just don't know how to do that.
Thanks,
Jeff
- DaneAOct 19, 2015NETGEAR Employee Retired
Hi jeffvenuti,
Are you able to access your data via SMB access using a PC/laptop? If yes, since you mentioned that the GUI does not seem to respond then you could manually backup the data by doing copy/paste from the NAS to an external drive or to a PC/laptop that has free space.
Ensure that you have a backup of your data first.
Check this article on how to set the NAS to telnet mode (tech support mode).
DaneA
NETGEAR Community Team- jeffvenutiOct 19, 2015Aspirant
Hi DaneA,
I will try restarting into tech support boot mode when I get home this evening. How will I know if it has been successfull? Can I use putty to telnet into it or something like that?
If I can't enable SMB mode (which may be the case since I can't enable other services like SSH), then can I use "Volume Read only" boot mode to backup date? How does one access data in that case?
Thanks,
Jeff
No content to show
