Marzz
Mar 07, 2016Aspirant
Power Timer - do_exit+844
ReadyNAS 104 Firmware 6.4.2 4 disks (4x Seagate ST3000DM001 3TB disk) Power Timer is Enabled. Every night when my system should turn off, it goes to sleep in some sort of coma. It ignores the...
- Mar 13, 2016
Hi Marzz,
Welcome to the community!
Give the 6.5.0-T322 Beta Firmware a try and let us know if it fixes the issue.
Kind regards,
BrianL
NETGEAR Community Team
kohdee
Mar 07, 2016Administrator
I believe we have a fix for this in 6.5.0, which a beta should soon be released.
Do you also have jumbo frames enabled? If so, you can work around this by going back to 1500 MTU.
- MarzzMar 08, 2016Aspirant
Thanks for your quick answer. :smileyhappy:
Teaming was on (Round-Robin)
Jumbo frames was on (set to 9000 MTU)
Now I lowered it to 1500 as you sugested.
I'll test this setting as soon as possible and come back with an answer.
Good to know this is part of the coming firmware update.
- MarzzMar 13, 2016Aspirant
Unfortunately lowering the network settings to 1500 MTU didn't work.
My readynas still didn't respond in the morning after I set this parameter.
Now I disabled the power-timer as a workaround and I'll wait for the firmware update.
- BrianL2Mar 13, 2016NETGEAR Employee Retired
Hi Marzz,
Kind regards,
BrianL
